13 years ago
Driver Error :WEB_SERVER example
I am using Quartus and Nios 11 SP2 .
I am trying to run the Web_server demonstration example.
When I try to compile the example using NIOS2 IDE after importing the files, its showing me an error as ./drivers/inc/altera_avalon_tse.h:96:33: error: altera_avalon_sgdma.h: No such file or directory. Hence the compilation is failing.
I included the file and also imported all the files from the local drive to the project. But failed to compile the project.
Thanks for your help.
Subbu
1 Reply
    Which hardware design are you using for the FPGA image? Is it a custom one or a ready made one? Does it have the SGDMA components for the Ethernet transfers?
