BIdro
6 years agoDriver Dedicated Transceiver Pin
I'm using Quartus Prime Software to program a Cyclone V GT FPGA.
I want to drive a differential pair of dedicated transceiver pins ( for example transmit a signal clock or packets without any...
- 6 years ago
HI Bryan,
Your questions is too high level but let me try my best to answer.
In general, I advise you to checkout the IP in user guide doc first as different IP solution may have its own design requirement.
Now to your questions
- In the Cyclone V family, is the IP compatible with GT/GX only?
- The IP can be used for both GT/GX channel.
- Main difference is the supported data rate
- When I use the IP, do I also have to define time constrains?
- The IP already has its own timing constraint but you still need to constraint your FPGA core own design logic path that interact/connect with the IP block.
dlim
Deshi_Intel
6 years agoHI Bryan,
dlim
