MOliv45
6 years agoDRC check CDC-50001 does not work if the given bit is part of a vector?
Summary: If the bit that is missing a synchronizer is part of a vector, the DRC check CDC-50001 FAILS. VHDL code: library IEEE; use IEEE.STD_LOGIC_1164.all; entity cdc is port ( clk1...
MEIYAN_L_Intel
6 years agoHi,
It seems like the output for pll_locked to output_a is not a timing path.
CDC rules only show violation for timing paths.
MOliv45
6 years agoHi,
Indeed. There is an internal request at intel to discuss if this port should be timed or not.
I believe it should. In one way or the other the DRC check has to be able to detect a missing synchronizer from an IP port, right?
Cheers.
