15 years agoAs far as I remember, a *.pof file will be generated automatically, if "use configuration device" is checked. I don't know, if the behaviour has been changed with Quartus V10.
You didn't tell, which problem you actually observe. It's also unclear, what's the role of the mentioned *.elf file. If you have a SOPC design involving a soft processor, then the respective tools should be used to integrate the image. But I won't expect a SOPC design without JTAG interface, because you're missing any debugging capability.
