8 years agoDoes SDK 16.1 support host channel, as described in Host Pipelined Multithread?
Hi, I found a new pipelined framework for high throughput design proposed in the document an831 - intel fpga sdk for opencl host pipelinedmultithread. I am using Arria 10 board and OpenCL SDK 1...
8 years agoThe actual code is probably not available to public, you can directly ask Intel to see if they will give you the code. Host channels are only supported in Quartus 17.1 and above and a compatible BSP only exists for Altera's reference Arria 10 board right now.
