OCn
5 years agoDoes quartus_map not use timing constraints
After studying "TimeQuest Timing Analyzer Quick Start Tutorial" (Document Version: 1.1, Dec. 2009 ), I found that timing constraints seem not applicable to the analysis & synthesis tool quartus_map. ...
- 5 years ago
Hi Oliver,
Unfortunately, there is no document available about this.
KhaiY
OCn
5 years agoHi KhaiY,
OK, I see.
Thanks, anyway!
Oliver
sstrell
5 years agoA document from 2009 is not going to describe this since synthesis support for .sdc was added later.
You don't need to do anything for this to work. It is just part of the compiler now. As long as you've added a .sdc file to the project (Assignments menu -> Settings -> Timing Analyzer), you're good to go.
- OCn5 years ago
Hi sstrell,
OK, I understand.
Your reply does solve my problem.
Thank you for your kind help!
Oliver
