13 years ago --- Quote Start --- UPDS = University Program Design Suite (Qsim + Waveform Editor). When I install upds 11.0 to run with Quartus II 11.1, it causes error when generating output waveform file, the Waveform Editor can not open the result. I have to downgrade Quartus II to 11.0 and it can work fine. --- Quote End --- I am facing the same problem, and I did as you did but still the output can not be seen, is the operating system has an effect? Thanks
