JDe_S4
8 years agoDoes Quartus 18.0 support the VHDL 2008 'ELEMENT attribute?
I am using the VHDL 'ELEMENT attribute to determine the range of an element in an array. ReadRegisterData: process (REG_CLK) is
begin
if (rising_edge(REG_CLK)) then
i_RegReadD...
MuhammadAr_U_Intel
Contributor
8 years agoHi Jacob,
Let me answer few of your questions.
- I have Quartus Prime Standard version 18.0 installed on my PC. When I click Help> Help topics it opens help locally from installation directory. "<Quartus install directory/quartus/common/help/webhelp/index.htm#quartus/gl_quartus_welcome.htm>" Can you confirm what version you are using. go to Help> About Quartus Prime.
- VHDL-2008 is not supported in Quartus Standard Edition, it is recommended to use Quartus Prime Pro for design using VHDL 2008.. Quartus feature comparison page referred by @Vicky is the latest and most accurate. https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/br/br-quartus-prime-software.pdf
Hope this clarifies.
Arslan
