JDe_S4
8 years agoDoes Quartus 18.0 support the VHDL 2008 'ELEMENT attribute?
I am using the VHDL 'ELEMENT attribute to determine the range of an element in an array. ReadRegisterData: process (REG_CLK) is
begin
if (rising_edge(REG_CLK)) then
i_RegReadD...
Tricky
8 years agoThere is an easy workaround for this (that works in '93):
-- If you know the array always contains index 0 (or some other fixed number):
i_RegReadData(i_DAC_CodeWordMaskReg(0)'RANGE)
-- You dont know the indeces
i_RegReadData(i_DAC_CodeWordMaskReg(i_DAC_CodeWordMaskReg'low)'RANGE)
