11 years agoDoes not found any template in nios (Quartus14.1)
when I choose the sopc.info and the program read this file finish I can't create niosII. It shows "There are no software examples available for the selected CPU" There is no template that ...
8 years ago --- Quote Start --- I had the same problem and the reason was a "bad" path: the folder name was using brackets "./project(v1.0)". brackets are ok for quartus but not for Eclipse. --- Quote End --- :-P:-P:-P Thank you!
