HKale1
7 years agoDoes it require a paid license to run OpenCL on DE10 Nano developemnt board ?
Hello Everyone, I want to build an application on the DE10 Nano development board using OpenCL. Does the Intel FPGA SDK require a paid license to compile and run OpenCL code on DE10 Nano I really ...
HRZ
7 years ago- The OpenCL code is [automatically] converted to verilog and then place and routed as normal. You need Quartus for placement and routing.
- If you want to use only HDL (Verilog/VHDL) on that board, Quartus lite will provide all the required functionality (including programming) without needing a license. If you want to use OpenCL, you need Quartus Prime Standard which requires a license.
- No license required for Quartus Lite. If you need OpenCL, you can ask your supervisor to apply for Intel's university program through which you can get a university license [for free] to use Quartus Prime Standard that supports OpenCL.
HKale1
7 years agoThanks a lot for your help
Hrishikesh
