9 years agoDoes clCreateProgramWithSource work?
I tried the example from the programming guide and got a status = 0, but then failures. status: 0 clCreateProgramWithSource status: -33 clBuildProgram status: -45 clCreateKernel pipe_writer...
9 years agoNobody in this forum has any control over Altera's decisions, you can open a support request through their support and request this feature.
Still, I am not particularly sure why you even need to use Altera's emulator for this purpose, when you can do the same thing by running the code on a standard CPU/GPU. There is not much of a reason to use Altera's emulator unless you are compiling kernels with channels, since they do not work on CPUs/GPUs. For every other case, you can simply run your kernel on a standard CPU/GPU which will be much faster and will also give you much more accurate emulation of concurrency/parallelism; something that Altera's emulator is not capable of doing.
