10 years agoDMA Interrupt not issued
I'm using Avalon msgDMA controller to do the DMA data transfer between a Nallatech pcie385n FPGA board and another PCIe device. I used OpenCL and Ubuntu OS as the programming platform. Also I modified the Altera Linux PCIe driver to implement this. In my code, I found that after the DMA descriptor is sent, I cannot get the DMA interrupt (the irq_status is 0). This problem occurs only in one data transfer direction and when transferring data in the other direction, the DMA interrupt is generated. I don't know why and does anyone know how come about this? Thanks!1 Reply
Ubuntu is not a supported OS for Altera OpenCL SDK & Nallatech's BSPs, can you please try on 64-bit CentOS / RedHat 6.x and see if the behavior is different? Thanks
