12 years agothanks all; hi kaz n is not a vector value to check lsb to it and i use mod function because n is integer . if i understand wrong could you plz illustrate it for me. but n*n & n*n-1 implies what? it will be square n and since dis is also 8 bits width then division will mostly be zero plus remainder. why division will mostly be zero plus remainder. could you plz illustrate it too.
