10 years agoDivided integer number
Can I divide the integer number (for example, 120) to each of the numbers 1 2 0 in different variables?
10 years agoHello please.
I need to show 12 -bit value (integer) of the AD converter to the 4 - digit display. This is my functional code, but takes 756 total logic elements (many). I need a way to effectively divide the number and use the minimum number of logic elements. library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity Number_converter is port( INPUT12bit: in unsigned (11 downto 0); digit1: out unsigned (11 downto 0); digit2: out unsigned (11 downto 0); digit3: out unsigned (11 downto 0); digit4: out unsigned (11 downto 0)); end entity; architecture main of Number_converter is signal INPUT12bit_INT:integer range 0 to 4096; attribute ramstyle: string; attribute ramstyle of digit4 : signal is "M9K"; begin digit1<=(INPUT12bit rem 10)/1; digit2<=(INPUT12bit rem 100)/10; digit3<=(INPUT12bit rem 1000)/100; digit4<=(INPUT12bit/1000); end main;
