10 years agoDivided integer number
Can I divide the integer number (for example, 120) to each of the numbers 1 2 0 in different variables?
10 years ago --- Quote Start --- From the AD converter to read 8-bit vector and the need to get him on the numbers in an integer. I need to send individual characters to UART --- Quote End --- Problem solved. This is example. library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity test is port( INput:in integer range 0 to 999:=123); end test; architecture main of test is signal hundred:integer range 0 to 9; signal ten :integer range 0 to 9 ; signal unit : integer range 0 to 9; begin hundred<=INput/100; --1 ten<=((INput rem 100)/(10)); --2 unit<=(INput rem 10) ; --3 end main;
