SparkyNZ
Contributor
5 years agoDisplaying Memory Contents in Signal Tap
How do you examine memory content with Signal Tap? bit [ 11 : 0 ] colorRGB[ 7 : 0 ]; When I add the above as a signal, I only see a high state representation. I can't find a Bus Display Format ...
- 5 years ago
Yes, select colorRGB.data_a to select the whole bus.
SparkyNZ
Contributor
5 years agoHi. Here's a link to what I'm seeing in the Node Finder:
https://i.imgur.com/z3MbgzY.png
So should I be including colorRGB.data_a[0] thru colorRGB.data_a[11] in my case?
(Sorry I cannot check - I have to go to work
sstrell
5 years agoYes, select colorRGB.data_a to select the whole bus.
