12 years agoDisplay two numbers with same switches on DE2
I am new to the forum and to VHDL as well. This is my second exercise on sequential circuits design. I am using the DE2 board and I should display two 16-bit hexadecimal numbers (A and B): A on HEX7-4 and B on HEX3-0. Values of A and B are configured via switches SW{15-0}; first the value of A and then the value of B. To do so, it is asked that the value of A be stored in the circuit. It is required also to use KEY{0} as an asynchronous reset and KEY{1} as a clock. I need to understand what I should do first before discussing the code. Am I going to use a register? I understand that I should configure the value of A via switches and press KEY{1} (the clock) to display it, and then do the same for B. Do you agree? But I don't see how to change the display from HEX7-4 to HEX3-0. Any help is much appreciated :) Thanks, Salooh
