16 years agoDifferential pair pins can be also used as two single ended I/O. You can see this from the device pinout tables. You have to keep distance rules between single ended and differential pins, they are checked by the Quartus fitter. You'll most likely have a somewhat increased crosstalk between p and n pins of a differential pair, depending on the board layout. If you are using the breakout board to connect the HSMC interface, you'll miss sufficient ground pins for single ended I/O.
