SSchm28
3 years agodifferent compile results on Linux- and Windows-version of Quartus Prime
On my workstation i run windows 10 and use Quartus Prime Lite 21.1.0 and all my projects compiles fine.
After setting up CI with a linux VM on an Buildserver one of my projects refu...
RichardT_altera
3 years agoYou probably looking at the Pro version document, Cyclone 10 LP is supported. Check the document link below:
https://www.intel.com/content/www/us/en/docs/programmable/683084/current/allow-register-merging.html
You can double check in the Assignment > Setting > Compiler Settings > Advanced Setting (synthesis). Search for Allow Register Merging and check that it is set as ON.
Richard Tan
- SSchm283 years ago
I double checked it as you suggested and Quartus tells me that it is ON.
But still, I got the same Analysis & Synthesis result as i run Quartus on a Windows machine and set the feature OFF.
In the end the Design does not fit into the FPGA and Fitter fails (on the Linux VM, un Windows it still works fine).
Any other suggestions ?
