15 years ago --- Quote Start --- how would you assign initial conditions in quartus --- Quote End --- By using signal initializers in VHDL respectively an initial block in Verilog.
SIGNAL b : std_logic := '1'; Quartus is inferring the register power-up state from this statement. Because newer FPGA families' LEs don't have an asnychronous set input, it performs "NOT gate push-back", inverting the register in- and outputs. See the Quartus Software Handbook: Volume I Design and Synthesis/Section II Design Guidelines/6. Recommended HDL Coding Styles/Coding Guidelines for Registers and Latches/Register Power-Up Values in Altera Devices The same statement is also used in simulation.
