10 years agoDifference between simulation and real test.
Hi all, I am a student and I am working on a homework. Shortly, I will summary the hw's requirement. It said some thing like that: At first, when counter goes from 0->7 then led 1 on; when the cou...
10 years agoI (too) think you should be more explicit with your case statement's 'default'. Why not:
default: Y=fer; This line:if (y==transfer && count==15) //This to reset the counterstands out to me. 'y' is moved on to 'flush' when count = 14. So, I don't think this condition can ever be true. On a more general note - use more descriptive signal/register names. I'd suggest 'y' and 'Y' are particularly poor. Use 'present_state' & 'next_state', as per your notes. Much clearer for anyone reviewing or you coming back to your code later.
