9 years agoDifference between area.rpt and "kernelname".area
Hello, I have compiled an example kernel and I found the files
- area.rpt - "kernelname".areain the bin folder. Does the file area.rpt shows the total amount of Hardware used (for the Kernel + BSP)? And the file vecadd.area shows the Hardwareelements used only for this function? In this files there is also a section called Util, can someone tell me what this stands for? (I can´t find a translation to german where this word makes sense in this context) Exampleoutput: LEs: 3.09659 % FFs: 1.89328 % RAMs: 7.7821 % DSPs: 0 % util: 4.68994 %
Can you attach the files to your reply? These reports have been renamed/removed/changed numerous times in different versions of AOC and these files that you mention do not exist in kernels compiled with v16.x and above.
I could be wrong (the version you are using is too old) but as you yourself said, the area.rpt is probably kernel + BSP while "kernel_name".area is kernel only. The "Util" field most likely shows your logic (ALM) utilization, i.e. the number of logic elements with at least one ALUT or register occupied in it.
