17 years agoIn quartus, you have to use the so called "constant functions". This is a function that operates only on cosntants, and so can be used during the first steps of the synthesis:
For example :module pulse(input Clk, input Reset, output Pulse);
parameter COUNTS = 33;
reg count;
assign Pulse = count == 0;
always @(posedge Clk or posedge Reset)
if (Reset)
count <= 0;
else
count <= count + 1;
//ceil of the log base 2
function integer CLogB2;
input Depth;
integer i;
begin
i = Depth;
for(CLogB2 = 0; i > 0; CLogB2 = CLogB2 + 1)
i = i >> 1;
end
endfunction
endmodule Stefaan
