11 years agoDesign using schematic
Hi guys. I have problem with my design. I have created my design using Megawizard plugin. But I am confused right now. Do we need to set clock and clken for my lpm_add_sub? here is my design. Y...
11 years agoSince you have enable the clock ports, the functionality of the module will be sync'ed with the clock. If you does not feed any clock to the module, it will not function as expected.
