10 years agoDesign Unit Not Found
Hello all, I'm still trying to get my *first* simulation running with ModelSim, and my progress is quite limited. I think I have my license issues worked out finally, after talking directly to ...
10 years agoHello,
--- Quote Start --- Does vlog work on vht test bench files normally? --- Quote End --- No. .vht stands for VHDL test bench file while vlog command compiles Verilog source code and SystemVerilog source codes. Hence it will not work. You should try following :- In Quartus, Go to Assignments -> Settings... -> EDA Tool Settings -> Simulation. In that select 'Verilog' under 'Format for Output Netlist'.
- In Quartus, Go to Processing -> Start... -> Start Test Bench Template Writer This should now create dac_top.vt file in same folder in which dac_top.vht file was being created before.
- Now try following command: vlog -reportprogress 300 D:/Users/
