10 years agoDesign Unit Not Found
Hello all, I'm still trying to get my *first* simulation running with ModelSim, and my progress is quite limited. I think I have my license issues worked out finally, after talking directly to ...
10 years ago --- Quote Start --- Hello, Thank you for your kind words. Whenever I am in trouble, someone on this forum helps me, so I am just trying do same. And I am glad that it is helpful to you. Anyway, let get back to our topic. vlog command compiles Verilog source code and SystemVerilog extensions into a specified working library while vsim command invokes the VSIM simulator. Consider tb_test is your test bench TOP file. In this case, first you need to compile this using vlog command. ( In the same way you are compiling your dac_top.v and other files.) Then you can use following command : vsim -L altera_mf_ver work.tb_test. Let us know whether it works or not. Cheers, Bhaumik --- Quote End --- Bhaumik, I think I am getting closer. Thank you. I decided to create a TestBench file. To do so, I used: Processing -> Start... -> Start Test Bench Template Writer This gave me a .vht file titled dac_top.vht. Next, I went to: Assignments -> Settings... -> EDA Tool Settings -> Simulation -> Test Benches... I created a new test bench titled 'dac_top_tb', and Top level module in test bench = 'dac_top_tb'. I added this file to the project as well. My .do file was automatically updated with a new vsim line, which includes all of the proper libraries:
vsim -t 1ps -L altera_ver -L lpm_ver -L sgate_ver -L altera_mf_ver -L altera_lnsim_ver -L stratixiv_hssi_ver -L stratixiv_pcie_hip_ver -L stratixiv_ver -L rtl_work -L work -voptargs="+acc" dac_top_tb
add wave *
view structure
view signals
run -all However, now I am getting a very similar answer to before- however, I don't know what library my test bench is in? # vsim -t 1ps -L altera_ver -L lpm_ver -L sgate_ver -L altera_mf_ver -L altera_lnsim_ver -L stratixiv_hssi_ver -L stratixiv_pcie_hip_ver -L stratixiv_ver -L rtl_work -L work -voptargs=""+acc"" dac_top_tb# Start time: 16:16:42 on Mar 22,2016# ** Error: (vsim-3170) Could not find 'D:/Users//Desktop/Research/QuartusII/March2016/DACSimulation/simulation/modelsim/rtl_work.dac_top_tb'.# # Error loading design Can you see what I am doing wrong?
