10 years agoDesign Unit Not Found
Hello all, I'm still trying to get my *first* simulation running with ModelSim, and my progress is quite limited. I think I have my license issues worked out finally, after talking directly to ...
10 years agoHello,
Thank you for your kind words. Whenever I am in trouble, someone on this forum helps me, so I am just trying do same. And I am glad that it is helpful to you. Anyway, let get back to our topic. vlog command compiles Verilog source code and SystemVerilog extensions into a specified working library while vsim command invokes the VSIM simulator. Consider tb_test is your test bench TOP file. In this case, first you need to compile this using vlog command. ( In the same way you are compiling your dac_top.v and other files.) Then you can use following command : vsim -L altera_mf_ver work.tb_test. Let us know whether it works or not. Cheers, Bhaumik
