10 years agoDesign Unit Not Found
Hello all, I'm still trying to get my *first* simulation running with ModelSim, and my progress is quite limited. I think I have my license issues worked out finally, after talking directly to ...
10 years ago --- Quote Start --- Hello FrenchyRaoul, First, you have been able to add that library in your search path. ( See "C:/altera/15.1/modelsim_ae/altera/verilog/altera_lnsim" in your message. Modelsim looked into that path. ) That's good. Second, sorry my mistake. 'allpll' is not a part of library I mentioned previously. So, please add following library ( altera_mf_ver ) in same way you added altera_lnsim_ver. As mikedsouze mentioned, you need to COMPILE them.Just presence of those files at above location is not enough. (I think this is alternative way. That is you can either compile these files or you can add libraries using vsim -L. ) Hope to be able to solve at least issue with 'altpll'. If it works, then for other modules you may also need to add other libraries in following way.( vsim -L altera_mf_ver -L alter_lnsim_ver ) Cheers, Bhaumik --- Quote End --- Bhaumik, you've been very helpful so far. I ran the following:
ModelSim> vsim -L altera_mf_ver work.TX_PLL# vsim -L altera_mf_ver work.TX_PLL # Start time: 16:49:04 on Mar 17,2016# Loading work.TX_PLL# Loading altera_mf_ver.altpll# Loading altera_mf_ver.ALTERA_DEVICE_FAMILIES# Loading altera_mf_ver.pll_iobuf# Loading altera_mf_ver.MF_stratixiii_pll# Loading altera_mf_ver.ttn_m_cntr# Loading altera_mf_ver.ttn_n_cntr# Loading altera_mf_ver.ttn_scale_cntr This 'worked', and opened up a simulation! Cool! Okay, so, moving forward, I want to be able to simulate my top level file. Here is what my .do file looks like: transcript onif {} {
vdel -lib rtl_work -all
vlib rtl_work
vmap work rtl_work
vlog -vlog01compat -work work +incdir+D:/Users//Desktop/Research/QuartusII/March2016/DACSimulation {D:/Users//Desktop/Research/QuartusII/March2016/DACSimulation/dac_top.v}
vlog -vlog01compat -work work +incdir+D:/Users//Desktop/Research/QuartusII/March2016/DACSimulation {D:/Users//Desktop/Research/QuartusII/March2016/DACSimulation/signalROM_verilog.v}
vlog -vlog01compat -work work +incdir+D:/Users//Desktop/Research/QuartusII/March2016/DACSimulation {D:/Users//Desktop/Research/QuartusII/March2016/DACSimulation/daccounter_verilog.v}
vlog -vlog01compat -work work +incdir+D:/Users//Desktop/Research/QuartusII/March2016/DACSimulation {D:/Users//Desktop/Research/QuartusII/March2016/DACSimulation/ALTDDIO_CLK_OUT.v}
vlog -vlog01compat -work work +incdir+D:/Users//Desktop/Research/QuartusII/March2016/DACSimulation {D:/Users//Desktop/Research/QuartusII/March2016/DACSimulation/ALTDDIO_TX.v}
vlog -vlog01compat -work work +incdir+D:/Users//Desktop/Research/QuartusII/March2016/DACSimulation {D:/Users//Desktop/Research/QuartusII/March2016/DACSimulation/TX_PLL.v}
vlog -vlog01compat -work work +incdir+D:/Users//Desktop/Research/QuartusII/March2016/DACSimulation {D:/Users//Desktop/Research/QuartusII/March2016/DACSimulation/dataclk_pll.v}
vlog -vlog01compat -work work +incdir+D:/Users//Desktop/Research/QuartusII/March2016/DACSimulation/db {D:/Users//Desktop/Research/QuartusII/March2016/DACSimulation/db/tx_pll_altpll.v}
vlog -vlog01compat -work work +incdir+D:/Users//Desktop/Research/QuartusII/March2016/DACSimulation/db {D:/Users//Desktop/Research/QuartusII/March2016/DACSimulation/db/dataclk_pll_altpll.v}
How can I tell my .do file where to look for the library? Is it the same -L flag for the vlog command? Hopefully I'm moving in the right direction. If I want to have a testbench, or be able to simulate my top level module using a fake simulated clock, can this be done in a .do file? I'm sorry for getting off topic, but you've been very helpful so far.
