10 years agoDesign Unit Not Found
Hello all, I'm still trying to get my *first* simulation running with ModelSim, and my progress is quite limited. I think I have my license issues worked out finally, after talking directly to ...
10 years agoHello,
Let's try to first solve issue with ALTPLL. You should be able to solve it by adding following library : altera_lnsim_ver. Does this name appear in your list of libraries? Now, question is where to add this? If you are using do file then, following command should help. vsim -L <library_name>. This -L command is used to search library for design units instantiated from Verilog and for VHDL default component binding. Please try this item and be relaxed. We should be able to solve this. Have a Good Day! Bhaumik
