gbassi
6 years agoDesign Space Explorer segmentation violation
Hi all,
recently I am experiencing a segmentation violation error when trying to compile a Quartus project with the DSE. The single compilation is completed correctly by Quartus, from Analysis&Synt...
- 6 years ago
Can you try running DSE using command line ?
KhaiY
KhaiChein_Y_Intel
6 years agoHi Giovanni,
Generally, bugs are fixed in the newer version of the software. Since you could not upgrade the design to the latest version, v20.1 to verify if this is fixed in the software, you may use command line as a workaround for v18.1
KhaiY
