11 years agoReview the fitter resource utilization reports. What you'll possibly find is that each of your 16x32 ROM are consuming (1) M9K block, using (4) blocks with capacity >32,000 bits even though you're only using 2,048 of them. i.e. your design doesn't map efficiently to the available hardware resources and you may need to rethink some things.
http://www.altera.com/literature/hb/cyc3/cyc3_ciii51004.pdf
