11 years agoThis is usually a result of the designer using the ram blocks inefficiently. If each of these takes a ram block, thats 9k bits per ram. And even the largest S3 part only has 1000 M9Ks. From your description, Im guessing you are using the rams highly inefficiently.
Without any code, it's difficult to see what you're doing.
