pavanhegde
5 years agoDesign facing fitter congestion need help
Hello Intel community,
Device used : 10AX057K4F35I3SG Family: Arria 10
I am facing the following and any help highly appreciated. I have a huge design and I am getting routing congestion warning...
Nurina
5 years agoHi Pavan,
In my opinion it's best to use up around 80-90% resources so you can use the free resources for debugging like SignalTap. If you don't plan on using SignalTap then I think 97% is fine.
With regards to the inconsistent resource usage, this is expected because you didn't set logic lock region, so the fitter will place & route your design differently at each compilation, using different amount of LAB.
Nurina
