Design Example for LVDS rx in MAX10
Do you know why your data is not aligned sometimes?
Here's some videos on LVDS IP that you can refer to:
1. https://www.youtube.com/watch?v=02lgfcxSjQA
2. https://www.youtube.com/watch?v=EAJ4BIiH-6I
Thank you,
Amin
- m_kumar5 years ago
Hi ,
Initially i want to detect an 12'hE9C idle pattern for some clock cycles (ex: 282 clocks), output of lvds rx ip output is 6 bit and i am using shift register to convert 6 bit to 12 bit.
required output E9C = 111010011100 .
sometimes i receive: 110100111001, 100111010011, like that for every power on bit position was changing from one position to other position.
Now i need to write bit slip logic using state machine or in Quartus has any built solution for this.
manoj
- AminT_Intel5 years ago
Hello Manoj,
You can refer to Data Realignment Block (Bit Slip) in this document on page 27: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_lvds.pdf
Thank you
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
