11 years agoDESCRIPTOR MEMORY for SGDMA is not defined in system.h file
Hi everyone, I am new to altera and FPGA programming. I want to use two SGDMA for transfer and receive of data from a TSE ip core. For that I am using a separate Descriptor memory along with the p...
11 years agoYou are probably using the Web edition of quartus. If you don't have a license, you can't use /s or /f nios without the time_limited warning. When you download your time_limited sof onto the FPGA, there will be a pop up window that pops up. Don't close that window. Then you should be able to download the ELF file.
Or you can switch to the /e version of nios.
