11 years agoDESCRIPTOR MEMORY for SGDMA is not defined in system.h file
Hi everyone, I am new to altera and FPGA programming. I want to use two SGDMA for transfer and receive of data from a TSE ip core. For that I am using a separate Descriptor memory along with the p...
11 years agoHi @krasner ,
Thanks for the reply. That issue got solved. I changed the base address of the descriptor memory and regenerated the .sopcinfo file. Can't tell though if the address was the culprit. I have got another problem. Whenever I try to download the software on to the FPGA, it gives the following error. --> "Downloading ELF Process failed." When I check the 'Run Configurations', it gives shows the following, --> "The expected Stdout device name does not match the selected target byte stream device name." Can you help me on this? I have tried regenerating the BSP, still the problem persists. The output .sof file shows time_limited. Has that anything to do?
