8 years agoDelaying all incoming signals by 2 ms using VHDL
Hi to all, I'm a finance student and I'm also interested in electronics, these days I do program because my limited of knowledge of this, so ask for help in here.I have two incoming signals that I wa...
8 years agoThat's not the only tricky part. The other tricky part going along with that one is the clock stability. Will the clock, 1,000,000 clocks later, be the 2ms you want at all times? Perhaps 2ms might wander between a delay of 0,999,900 and 1,000,100. If you want to keep the actual delay exact, then you'll need to be careful about what external source provides you with your clock.
Dan
