9 years agodegedge count problem..
Hi, I have a very simple verilog code. But I get wrong result. When I look through the oscilloscope, I see 10 negative edges. But the result I get with a simple code that I write is sometimes 12, som...
9 years agoWhat is SCL? is it the clock from an SPI bus? for this, usually it is safer to use a fast system clock and sample the SCL with the fast system clock.
