14 years ago --- Quote Start --- _In the TimeQuest User Guide, p. 19, with reference to the previously discussed commands: "set_output_delay -clock dac_clk_ext -max 0.0 [get_ports DAC_DATA[5]] set_output_delay -clock dac_clk_ext -min 0.0 [get_ports DAC_DATA[5]]" it is said: "With both -max and -min at 0, we are stating that there are no external delays, and basically have no affect on the analysis." In my understanding, I would expect these commands to already say that those ports are synchronous to dac_clk_ext clock, so default setup and hold relationships should be applied as the sink registers were into the FPGA. I suppose I'm wrong, but where? --- Quote End --- The set_output_delay constraint describes what happens to the signal once it leaves the chip, using an "ideal" reference. With the constraint above you're telling that the signal DAC_DATA[5] - after it leaves the FPGA pin, the signal will go through a zero delay - and then it will be captured at the instant of the rising edge of dac_clk_ext Ie, you're describing an ideal system where - there's no delay from the FPGA pin to the DAC pin - there's no delay from the source* of the dac_clk_ext to the DAC's clock pin - the DAC input has zero tSU and zero tH * source, as specified in the create_clock/create_generated_clock constraint.
