GGeor5
8 years agoDefine a partition in Quartus for a block that includes tranceivers
I am trying to use design partition in Quartus. I lock down a block after it has satisfied the timing constraints. Since the block includes transceivers I get an error indicating it should be on the ...
sstrell
8 years agoIn the Pro edition, all periphery resources (including the transceivers) are part of the root_partition (the top-level of your design plus any lower-level core logic that is not isolated into its own design partition). It sounds like you want to perform periphery design reuse. Check out the design block reuse flows here:
