15 years agoright out of my i would say yes, i remember an avalon specific document that gave some very useful hints about the recomended syntax for custom ip signals that are connected to the avalon switch fabric.
that document recomended to group and name signals so sopc builder & component editor would automatically recognize them (it works!) start naming with avs_ for Avalon Valid Slave, or gls_ for global signal follow by your interface name like myinterface_ if that signal is intended to leave sopc avalon and should be exported to top level add export_ and finaly your custom name, or the avalon signal name you want to connect to like address you will end up with these names for example avs_myinterface_chipselect or avs_myinterface_export_myoutput or gls_clk that document also explained how sopc builder automaticaly connects signals between 2 ips, so sopc builder should be able to do these connections but i am not shure if it would connect a complex bus interface
