10 years agoDEAD TIME TO CONTROL 2 SYNCHRONOUS MOSFET (BUCK CONVERTER) help!!!!!!!
HELLO. I AM A STUDENT AND I AM TRYING TO IMPLEMENT AN STATE MACHINE TO CONTROL A BUCK CONVERTER. IN THIS PART OF CODE, I AM TRYING TO COMMUTE 2 MOSFET (HIGH SIDE AND LOW SIDE). EACH 20ms MOSFET1 ...
10 years agoYour 'counter' needs to count to 'timeM' + 'timeR'.
Then, in your 'commutation' process, you need to test for 'counter=timeM' - when you turn both FETs off - and for 'counter=(timeM+timeR)' - when you turn the next FET on. Cheers, Alex
