8 years agoDE5aNet-DDR4 opencl17.1 setup question
I"m trying to set up my DR5aNet DDR4 FPGA board. I installed OpenCL and Quartus Prime properly, following the manual. But the problem is I cannot compile a test project of fft1d.cl into fft1d.aocx. ...
8 years agoActually I made a mistake, the multiple variants is for the DDR3 version of the board, you seem to be using the DDR4 version which only has one variant. Anyway, Terasic's BSPs generally lack proper testing and new versions are regularly problematic; this could be just another failure on their part to properly test their BSP before releasing it. Based on your logs, the process is failing when Quartus is trying to import the BSP which is likely due to an issue with the BSP itself. I recommend contacting Terasic directly since only they can address BSP-related issues.
