14 years ago[DE1] [Quartus 11.1sp2] EPCS4, active serial programmation and pof file
Hi everyone, I've a problem while trying to load my configuration file in the DE1 EEPROM (EPCS4). This file should configure the Cyclone II FPGA (EP2C20F484) at boot. I'm using Quartus 11....
11 years ago --- Quote Start --- Ok, i found the solution here: I would just add that unlike what is said in the DE1 user manual, to program the EPCS4 EEPROM whith those steps, the RUN/PROG switch has to be on RUN. Good luck, J-B --- Quote End --- Wow Thx It helps a lot lol
