14 years ago[DE1] [Quartus 11.1sp2] EPCS4, active serial programmation and pof file
Hi everyone, I've a problem while trying to load my configuration file in the DE1 EEPROM (EPCS4). This file should configure the Cyclone II FPGA (EP2C20F484) at boot. I'm using Quartus 11....
14 years agoOk, i found the solution here:
--- Quote Start ---- open File > Convert Programming Files
- select .jic (JTAG indirect) as the output type
- select appropriate EPCS device
- click SOF data, then Add File to add your .sof
- click properties to optionally enable compression
- click Flash Loader then Add Device to select your target device
- click Generate
- open Tools > QII Programmer
- click Auto Detect
- double click in File column of your FPGA device row
- select .jic file
- click the Program/Configure check box in the new EPCS device listed
- click Start
