10 years agoDE0-NANO and Qsys : error when quit Qsys tools
Hi, I begin to use Quartus 15.0 and Qsys. I want create a ADC project. I use Qsys tools. I put CPU : Nios II (Classic) Processor. When I quit Qsys tools, i have this error (I didn't generate): ...
10 years agoAs said by Alex, this is not an error. Everyone sees this when exiting QSYS after creating a system. You need to successfully generate the QSYS system before the qip file is created. The qip file is created in a directory with the same name as your QSYS system. If you are using windows, the find file feature can locate if for you, just search for *.qip. In order to have the QSYS system included in your quartus project, you need to add the file as Alex mentioned.
