8 years agoDE 10 standard board opencl
Hi, I am newbie of the OpenCL and use the DE10 board standard. I want to use the board with only OpenCL. That is CPU is the host and DE10 board only support OpenCL and communicate each other. ...
8 years agoWhat do you mean by "CPU is the host"? This board already has an OpenCL BSP provided by Terasic which you can use. In this case, the ARM core on the package will act as the host, and the FPGA will be the device. Since this board does not have PCI-E connectivity, you cannot connect it to a PC and use the PC's CPU as OpenCL host.
