DDR4 example design仿真
- 5 years ago
Hi pp,
You actually doing it right.
After performing commands do msim_setup.tcl, you should perform the commands like below:
- dev_com
- com
- elab_debug
- add wave "ed_sim/*"
- transcript file transcript.txt
- run -all
I already share the run.do file at my first comment there.
It's contains the commands to simulate your design.
In order to use it,
- Copy the run.do into your msim_setup.tcl directory
- Open Modelsim
- Change directory to your msim_setup.tcl directory
- Perform do run.do in the transaction windows
Feel free to ask me when you still need some help.
Adzim
HI Adzim:
I have used the DO file you gave for simulation, but the simulated signal waveform is not available, and many signals are red lines
Hi pp,
Great to know.
You should wait until the simulation finish.
Also you need to select Full Calibration mode to see the full processes in your EMIF IP setting.
Or else there might be skipped the calibration.
But the Full Calibration mode will take longer time than Skip Calibration mode.
I see that you can run the simulation now.
I guess your problem is solved.
Do you any further question?
Adzim
- pp5 years ago
thank you Adzim, No more questions for me
