DDR4 example design仿真
- 5 years ago
Hi pp,
You actually doing it right.
After performing commands do msim_setup.tcl, you should perform the commands like below:
- dev_com
- com
- elab_debug
- add wave "ed_sim/*"
- transcript file transcript.txt
- run -all
I already share the run.do file at my first comment there.
It's contains the commands to simulate your design.
In order to use it,
- Copy the run.do into your msim_setup.tcl directory
- Open Modelsim
- Change directory to your msim_setup.tcl directory
- Perform do run.do in the transaction windows
Feel free to ask me when you still need some help.
Adzim
Hi Adzim:
Does the Modelsim shows any error in the transaction windows?
Or there is no reaction at all?
answer: please look at the picture,when i input command do msim_setup.tcl
Can you confirm that the msim_setup.tcl is exists in your directory?
answer : yes,i'm sure the msim_setup.tcl is exists my directory, please look at the picture
Have you tried to change the directory in the GUI?
You can change it by going to File>Change Directory...
answer : yes, I used exactly the method you said
by the way, i'm using quartus 18.0 standard version
Hi pp,
- dev_com
- com
- elab_debug
- run -all
In order to use it,
- Open Modelsim
Adzim
